Date/Time: Wed, 22 Jan 2025 23:27:34 +0000
set all charts to candlestick
View Count: 2595
[2018-10-01 19:26:21] |
User389493 - Posts: 16 |
Is there a setting somewhere that will force all future charts to be shown with candlesticks?
[2018-10-03 21:21:17] |
Yes there is. Refer to: Using Chart Templates Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-03 21:21:25] |
Refer to the following: Using Chart Templates: Setting Default Chart Settings For New Charts
[2018-10-04 00:42:03] |
Thank you. However, on my trial copy of Sierra Charts, when I go to Chart>>Chart Settings, most of the options are greyed out. Graph Draw Type is also greyed out.
[2018-10-04 01:53:05] |
Definitely the Save Days to Load, Intraday Bar Period, Graph Draw Type as Default option will not be disabled. Being on a trial has no effect on settings at all. And also the Graph Draw Type list box in Chart >> Chart Settings is never disabled. There is no such thing. We cannot possibly believe that. Provide us a screenshot showing what you are seeing. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-04 01:59:23
[2018-11-03 22:43:39] |
Thanks, everyone, it's working now. I didn't see the little box for saving the settings.
