Date/Time: Wed, 22 Jan 2025 11:38:33 +0000
Sierra chart keep shutting down when i open one particular chart
View Count: 594
[2018-10-01 18:51:23] |
User807128 - Posts: 18 |
I uploaded E moji indicators and that chartbook was ok for a while.however , each time I open that chart book , Sierra shuts down right away. I have installed service pack3 latest versio 1841. Chartbook: https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=22463 |
[2018-10-02 01:12:28] |
This is going to be caused by the custom studies almost certainly. Run Sierra Chart for now in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode If that resolves the issue, then work with the indicator provider to get this issue resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
