Date/Time: Wed, 22 Jan 2025 11:51:26 +0000
Distracting New lines
View Count: 569
[2018-10-01 14:49:17] |
Dodders - Posts: 20 |
Since upgrading to the latest version two horizontal black lines have appeared as shown by arrows in the attachment. These lines are a distraction and so could you direct me to the setting whereby i can hide them. If this setting is not available please remove them at the earliest convenience.
Capture.PNG / V - Attached On 2018-10-01 14:43:28 UTC - Size: 98.19 KB - 243 views Attachment Deleted. |
[2018-10-01 19:00:10] |
It seems to be related to the tab bars which are in the process of being replaced. So at this point we are not going to spend any time on this.
[2018-10-02 15:42:24] |
No problem, I've reverted to 1795 until the new development resolves the issue.
