Date/Time: Sun, 24 Nov 2024 11:49:28 +0000
Data Feed required for Daily / Weekly Number bar study
View Count: 1285
[2013-10-27 16:14:51]
Moti - Posts: 63
Which Data feed I need to Have to see Daily bar ( Futuers ) with " Pullback" information from "Number Bar - old" For a minimum period of 90 days.
Same for weekly bar
Thank you,
Moti
[2013-10-28 16:47:12]
Any of the ones listed here:
http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ServicesThatSupportBVandAV
You will need to use Intraday chart data to create the daily and weekly bars. The instructions here explain how this can be done:
http://www.sierrachart.com/index.php?l=doc/helpdetails13.html#DaySessionOnlyDaily
