Date/Time: Wed, 22 Jan 2025 11:53:22 +0000
Bollinger Squeeze 2 / Modification Possibility
View Count: 983
[2018-10-01 13:48:18]
User371906 - Posts: 141
I would like to know how to change color in Bollinger Squeeze 2, SG1 has ability to change color but the second (darker shade of green & red) already preset color has not ability to change in Study Settings and Inputs.
Would like be able to set just one color for all and with this be able to set it in Chart Region 1 as Background Transparent as to gauge trend side using this study..
Tried all forum links and also Notepad++ for hours but no go.
Please let me know possibilities.
Thank You
Regards
g
Date Time Of Last Edit: 2018-10-01 14:03:43
imageBollinger Squeeze 2 Mod.JPG / V - Attached On 2018-10-01 13:47:44 UTC - Size: 220.18 KB - 258 views
[2018-10-01 19:25:20]
You can modify this study. Refer to:
How to Build an Advanced Custom Study from Source Code
The study can be found in /ACS_Source/studies6.cpp.
