Date/Time: Wed, 22 Jan 2025 11:50:05 +0000
Rithmic spreads
View Count: 1195
[2018-10-01 13:43:07] |
User548845 - Posts: 8 |
Are Rithmic spreads supported? I can't seem to find the exchange traded spread for CLX8-CLZ8. Thank you. |
[2018-10-01 13:49:41] |
User895472 - Posts: 6 |
I think you should be able to create chart at least. Perhaps you dont have symbols right...
[2018-10-01 13:53:58] |
I can only find instructions for spreads on CQG, not rithmic.
[2018-10-01 19:26:00] |
Refer to: Rithmic Trading Platform Service: Exchange Traded Spreads/Strategies
