Date/Time: Wed, 22 Jan 2025 11:41:38 +0000
Fill Top/Fill Bottom visual changes
View Count: 575
[2018-10-01 04:32:08]
TechTrader - Posts: 116
The visual appearance of Fill Top/Fill Bottom Graph Draw Style changed around SC1809 from a complete fill to one with very narrow vertical gaps at every bar interval.
SC1814 has reverted to the complete fill.
The change in SC1809 indicated the bar intervals while still showing a filled band.
Personally, I found the change visually pleasing as I could still see the bar intervals.
Any chance of that display as an option in future releases?
[2018-10-01 22:09:42]
Further to post#1 I have tried reverting to SC1809 but the display shows at it did on all previous versions.
I do have another install of SC1809 which has not been upgraded.
The screenshot shows the Fill Top/Fill Bottom with the separation lines.
Selecting Fill Rectangle Top/Fill Rectangle Bottom displays totally filled as all previous versions.
http://www.sierrachart.com/image.php?Image=1538431717126.png
