Date/Time: Wed, 22 Jan 2025 11:53:17 +0000
Fixed Width Multi VP
View Count: 651
[2018-10-01 02:11:31] |
trad - Posts: 43 |
Is is possible to fix the width of multiple volume profiles which I am displaying on right of a chart? They are day, week, year volume profile. And depending on time frame I select, they distort/adjust a lot. Can their width be fixed regardless of what time frame I am using? |
30 min.PNG / V - Attached On 2018-10-01 02:10:11 UTC - Size: 67.06 KB - 247 views |
[2018-10-01 17:19:57] |
The volume bars cannot be relative to each other but they can be set to occupy the same amount of space on the chart window if that is what you want?
[2018-10-02 11:22:22] |
trad - Posts: 43 |
yes, at all time frame, i want the volume profile on the right to take same amount of chart space. can you please share the settings. i have basically tinkered with everything i can personally think of, but i need some help with it now. thanks. |
[2018-10-02 18:07:44] |
You need to set this particular Input: Volume By Price Study: Maximum Volume Bar Width Type To Window Width. This is all the help we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
