Date/Time: Fri, 24 Jan 2025 00:25:35 +0000
How to cancel buy-limit or cancel sell-limit orders of the party separately from each oth?
View Count: 883
[2018-09-28 20:04:31]
User669282 - Posts: 5
Cancel buy-limit or cancel sell-limit button function is on many less advanced platforms.
Tell me please, does Your Grand Team plan to create such buttons?
If You do not plan, could You give an example of creating a command method.
Thanks for the answer.
Thank You for Your the best trading platform.
Date Time Of Last Edit: 2018-09-28 20:07:26
[2018-09-28 20:48:13]
Okay we will put these in.
[2018-09-29 12:19:49]
Cool! Thank you!
[2018-09-29 13:53:56]
User572956 - Posts: 7
I also look forward to this functionality with impatience
[2018-11-12 17:46:05]
We will try to get to this, this week.
[2018-11-19 13:40:24]
User703614 - Posts: 8
Are these buttons TCСSO and TССBO?
[2018-11-19 21:43:05]
Yes those are them. You can customize the names as required.
You can also set up keyboard shortcuts and those commands are also available through the Chart Trade menu:
Global Settings Menu: Customize Chart Trade Menu (Global Settings menu)
Date Time Of Last Edit: 2018-11-19 21:43:11
[2018-11-20 19:19:38]
In the Chart Trade menu, they work well!
But button function do not work when added to the Customize Control Bar and Customize Keyboard Shortcuts.
Thank You!
SC 1842 64-bit
Date Time Of Last Edit: 2018-11-20 19:32:22
[2018-11-20 20:15:26]
This will be solved in the next release.
[2018-12-23 10:43:13]
Thank!
With the installation of version 1853 everything works.
Very important and useful functionality.
Your team is very attentive and responsive.
True professionals!
Thanks again!
[2018-12-23 17:36:01]
Thank you.
