Date/Time: Wed, 22 Jan 2025 12:56:43 +0000
Historic Data
View Count: 619
[2018-09-28 19:57:45] |
User723592 - Posts: 9 |
Hi, I have been trying to download intraday data for the ES continous contract going back to 2007 but I only get data in a text file until 2013; what setting do I need to adjust? cheers hf jr. |
[2018-09-29 19:46:39] |
We see that you have not logged into your Sierra Chart account. This is the one that you have started this Support Request with. Log into Sierra Chart with this account following these instructions here: Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name Here is the relevant documentation for your question: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-01 13:19:13] |
Thank you very much.... it is working for daily and higher timeframe charts, however, it does not work for intraday charts... still it looks that I only get 5years of intraday data... is there a way to get more intraday data?
[2018-10-01 18:38:53] |
For what symbol do you want to get more than five years of data for? And reread the documentation we linked to above. It is very clear on this subject. Most likely you overlooked something: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-01 19:05:50
