Date/Time: Thu, 03 Apr 2025 19:31:33 +0000
Draw old filled transactions from a csv file onto chart?
View Count: 775
[2018-09-28 04:05:42] |
User517452 - Posts: 27 |
Is there a sample code that can draw old filled transactions from a csv file onto chart? The csv file contains symbols, execution time, execution price, quantity...
[2018-09-28 15:47:22] |
John - SC Support - Posts: 39147 |
Here is a documentation for importing order fills: Trade Activity Log: Importing and Exporting Data But the format is not documented but you can tell what the format is by exporting any existing order fills. If you do not have any, perform some simulated trading to create some. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 18:23:49
