Date/Time: Wed, 22 Jan 2025 12:49:58 +0000
Silver Tick Value Incorrect
View Count: 870
[2018-09-27 21:37:30]
User104854 - Posts: 457
When I pull up the contract for Silver (F.US.SIEZ18) it says that the tick value is $5 per tick but it's actually $25. My data feed is CQG. I did a search online and have found that I'm not the only one that has seen this on Sierra Chart. I've gone into Symbol settings and have changed it to $25 but on my spreadsheet it still shows up as $5 per tick. This is the only symbol I've noticed it with.
Can you confirm the tick value for this contract?
I'm hoping you can fix it but if not how can I do it so that the right value shows up in the spreadsheet?
Thanks.
[2018-09-28 09:02:26]
Fixed.
