Date/Time: Sun, 24 Nov 2024 11:02:01 +0000
SC, Intraday Continuous contract needs further improvement. IT IS JUST TOO SLOW.
View Count: 1375
[2013-10-26 20:40:52] |
abrown8703 - Posts: 64 |
SC Support/Engineers, is there any plans to improve on the time it takes to load a continuous contract? IT IS JUST TOO SLOW. Is there anything that we can do to improve upon this, such as, changing a setting? To your continued success! |
[2013-10-28 14:23:16] |
M5amhan - Posts: 468 |
if you go to Global Settings > General Settings and play around with Chart Update Interval In Milliseconds until it loads to your preference.. it does use more CPU the lower the number though
[2013-10-29 00:05:00] |
Yes. We do plan improvements with this by the end of the year.
