Date/Time: Wed, 22 Jan 2025 13:03:26 +0000
Find Symbol
View Count: 590
[2018-09-27 14:59:58] |
cnbrown - Posts: 3 |
why am I not able to use common symbols such as epz enqz. unable to find them in the search, comes up symbol does not exist. I have to use 20181200.cme_eq..does this have to do with the broker?
[2018-09-27 15:07:46] |
You must use the symbols that you see listed in File >> Find Symbol. Use those symbols and do not modify them.
