Date/Time: Sun, 24 Nov 2024 11:31:30 +0000
Spreadsheet Studies
View Count: 1303
[2013-10-26 19:36:13] |
s72444 - Posts: 1 |
Dear Support, How would I go about inserting data into a column of the spreadsheet when the data comes within 2 ticks of a trend-line. I am a c#/c++ programmer, I found a bunch of code in the source files but not sure how they interact with the GUI of the program. I want to insert custom data like a 0,1,2 in the BT column of the spreadsheet based on the data (ex. price by volume). Thanks Shaun Date Time Of Last Edit: 2013-10-26 19:36:31
[2013-10-28 17:25:55] |
This can be done by creating a custom study using ACSIL. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html ACSIL can access Line drawings on a chart. The results of the study will be outputted to the Spreadsheet when using the Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
