Date/Time: Wed, 22 Jan 2025 13:04:20 +0000
No live td ameritrade data for trading started today
View Count: 755
[2018-09-26 18:52:01]
User701754 - Posts: 4
TD Ameritrade | Streamer request #3790 initiated. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Signaling to core to close socket | 2018-09-26 12:58:17
TD Ameritrade | Lost the connection with the streamer. Request ID: 3790. Will re-request data. | 2018-09-26 12:58:17
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:17 *
HTTPS ameritrade02.streamer.com:443 (3938) | Received socket Close event. | 2018-09-26 12:58:17
HTTPS ameritrade02.streamer.com:443 (3938) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:17
TD Ameritrade | Streamer request #3791 initiated. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Signaling to core to close socket | 2018-09-26 12:58:19
TD Ameritrade | Lost the connection with the streamer. Request ID: 3791. Will re-request data. | 2018-09-26 12:58:19
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:19 *
HTTPS ameritrade02.streamer.com:443 (3939) | Received socket Close event. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3939) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:19
HTTPS ameritrade02.streamer.com:443 (3868) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3869) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3870) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3871) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3872) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3873) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3874) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3876) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3877) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3878) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3879) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3880) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3881) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3882) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3884) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3885) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3886) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3887) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3888) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3889) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3890) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3892) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3893) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3894) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3895) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3896) | Deleting network socket now after delay. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3897) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3897) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3898) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3898) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3899) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3899) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3900) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3900) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3901) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3901) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3902) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3902) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3903) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3903) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3904) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3904) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3905) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3905) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3906) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3906) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3907) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3907) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3908) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3908) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3909) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3909) | Closed. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3910) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:20
HTTPS ameritrade02.streamer.com:443 (3910) | Closed. | 2018-09-26 12:58:20
TD Ameritrade | Streamer request #3792 initiated. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:21 *
HTTPS ameritrade02.streamer.com:443 (3940) | Socket gracefully closed by remote side. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Received socket Close event. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Signaling to core to close socket | 2018-09-26 12:58:21
TD Ameritrade | Lost the connection with the streamer. Request ID: 3792. Will re-request data. | 2018-09-26 12:58:21
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-26 12:58:21
HTTPS ameritrade02.streamer.com:443 (3940) | Closed. | 2018-09-26 12:58:21
TD Ameritrade | Streamer request #3793 initiated. | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Signaling to core to close socket | 2018-09-26 12:58:23
TD Ameritrade | Lost the connection with the streamer. Request ID: 3793. Will re-request data. | 2018-09-26 12:58:23
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:23
HTTPS ameritrade02.streamer.com:443 (3941) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:24 *
HTTPS ameritrade02.streamer.com:443 (3941) | Received socket Close event. | 2018-09-26 12:58:24
HTTPS ameritrade02.streamer.com:443 (3941) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:24
TD Ameritrade | Streamer request #3794 initiated. | 2018-09-26 12:58:25
HTTPS ameritrade02.streamer.com:443 (3943) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:25
HTTPS ameritrade02.streamer.com:443 (3943) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:25
HTTPS ameritrade02.streamer.com:443 (3943) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:26
HTTPS ameritrade02.streamer.com:443 (3943) | Signaling to core to close socket | 2018-09-26 12:58:26
TD Ameritrade | Lost the connection with the streamer. Request ID: 3794. Will re-request data. | 2018-09-26 12:58:26
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:26
HTTPS ameritrade02.streamer.com:443 (3943) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:26
HTTPS ameritrade02.streamer.com:443 (3943) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:26 *
HTTPS ameritrade02.streamer.com:443 (3943) | Received socket Close event. | 2018-09-26 12:58:26
HTTPS ameritrade02.streamer.com:443 (3943) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:26
TD Ameritrade | Streamer request #3795 initiated. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Signaling to core to close socket | 2018-09-26 12:58:28
TD Ameritrade | Lost the connection with the streamer. Request ID: 3795. Will re-request data. | 2018-09-26 12:58:28
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:28 *
HTTPS ameritrade02.streamer.com:443 (3944) | Received socket Close event. | 2018-09-26 12:58:28
HTTPS ameritrade02.streamer.com:443 (3944) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:28
TD Ameritrade | Streamer request #3796 initiated. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Signaling to core to close socket | 2018-09-26 12:58:30
TD Ameritrade | Lost the connection with the streamer. Request ID: 3796. Will re-request data. | 2018-09-26 12:58:30
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:30 *
HTTPS ameritrade02.streamer.com:443 (3945) | Received socket Close event. | 2018-09-26 12:58:30
HTTPS ameritrade02.streamer.com:443 (3945) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:30
TD Ameritrade | Streamer request #3797 initiated. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:32 *
HTTPS ameritrade02.streamer.com:443 (3946) | Socket gracefully closed by remote side. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Received socket Close event. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Signaling to core to close socket | 2018-09-26 12:58:32
TD Ameritrade | Lost the connection with the streamer. Request ID: 3797. Will re-request data. | 2018-09-26 12:58:32
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-26 12:58:32
HTTPS ameritrade02.streamer.com:443 (3946) | Closed. | 2018-09-26 12:58:32
TD Ameritrade | Streamer request #3798 initiated. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Signaling to core to close socket | 2018-09-26 12:58:34
TD Ameritrade | Lost the connection with the streamer. Request ID: 3798. Will re-request data. | 2018-09-26 12:58:34
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:34 *
HTTPS ameritrade02.streamer.com:443 (3947) | Received socket Close event. | 2018-09-26 12:58:34
HTTPS ameritrade02.streamer.com:443 (3947) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:34
TD Ameritrade | Streamer request #3799 initiated. | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Signaling to core to close socket | 2018-09-26 12:58:36
TD Ameritrade | Lost the connection with the streamer. Request ID: 3799. Will re-request data. | 2018-09-26 12:58:36
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:36
HTTPS ameritrade02.streamer.com:443 (3948) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:37 *
HTTPS ameritrade02.streamer.com:443 (3948) | Received socket Close event. | 2018-09-26 12:58:37
HTTPS ameritrade02.streamer.com:443 (3948) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:37
TD Ameritrade | Streamer request #3800 initiated. | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Signaling to core to close socket | 2018-09-26 12:58:38
TD Ameritrade | Lost the connection with the streamer. Request ID: 3800. Will re-request data. | 2018-09-26 12:58:38
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:38
HTTPS ameritrade02.streamer.com:443 (3949) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:39 *
HTTPS ameritrade02.streamer.com:443 (3949) | Received socket Close event. | 2018-09-26 12:58:39
HTTPS ameritrade02.streamer.com:443 (3949) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:39
TD Ameritrade | Streamer request #3801 initiated. | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Signaling to core to close socket | 2018-09-26 12:58:40
TD Ameritrade | Lost the connection with the streamer. Request ID: 3801. Will re-request data. | 2018-09-26 12:58:40
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:40
HTTPS ameritrade02.streamer.com:443 (3950) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:41 *
HTTPS ameritrade02.streamer.com:443 (3950) | Received socket Close event. | 2018-09-26 12:58:41
HTTPS ameritrade02.streamer.com:443 (3950) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:41
TD Ameritrade | Streamer request #3802 initiated. | 2018-09-26 12:58:42
HTTPS ameritrade02.streamer.com:443 (3951) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:42
HTTPS ameritrade02.streamer.com:443 (3951) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:42
HTTPS ameritrade02.streamer.com:443 (3951) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:43 *
HTTPS ameritrade02.streamer.com:443 (3951) | Socket gracefully closed by remote side. | 2018-09-26 12:58:43
HTTPS ameritrade02.streamer.com:443 (3951) | Received socket Close event. | 2018-09-26 12:58:43
HTTPS ameritrade02.streamer.com:443 (3951) | Signaling to core to close socket | 2018-09-26 12:58:43
TD Ameritrade | Lost the connection with the streamer. Request ID: 3802. Will re-request data. | 2018-09-26 12:58:43
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:43
HTTPS ameritrade02.streamer.com:443 (3951) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-26 12:58:43
HTTPS ameritrade02.streamer.com:443 (3951) | Closed. | 2018-09-26 12:58:43
TD Ameritrade | Streamer request #3803 initiated. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:45 *
HTTPS ameritrade02.streamer.com:443 (3952) | Socket gracefully closed by remote side. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Received socket Close event. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Signaling to core to close socket | 2018-09-26 12:58:45
TD Ameritrade | Lost the connection with the streamer. Request ID: 3803. Will re-request data. | 2018-09-26 12:58:45
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-09-26 12:58:45
HTTPS ameritrade02.streamer.com:443 (3952) | Closed. | 2018-09-26 12:58:45
TD Ameritrade | Streamer request #3804 initiated. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Signaling to core to close socket | 2018-09-26 12:58:47
TD Ameritrade | Lost the connection with the streamer. Request ID: 3804. Will re-request data. | 2018-09-26 12:58:47
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:47 *
HTTPS ameritrade02.streamer.com:443 (3953) | Received socket Close event. | 2018-09-26 12:58:47
HTTPS ameritrade02.streamer.com:443 (3953) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:47
TD Ameritrade | Streamer request #3805 initiated. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Signaling to core to close socket | 2018-09-26 12:58:49
TD Ameritrade | Lost the connection with the streamer. Request ID: 3805. Will re-request data. | 2018-09-26 12:58:49
If the data feed does not resume, reconnect with 'File >> Disconnect' and 'File >> Connect to Data Feed'. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Shutdown started. Waiting for graceful close. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-09-26 12:58:49 *
HTTPS ameritrade02.streamer.com:443 (3954) | Received socket Close event. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3954) | Still waiting for graceful close or receive error. | 2018-09-26 12:58:49
HTTPS ameritrade02.streamer.com:443 (3897) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3898) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3899) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3900) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3901) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3902) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3903) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3904) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3905) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3906) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3907) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3908) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3909) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3910) | Deleting network socket now after delay. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3911) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3911) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3912) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3912) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3914) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3914) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3915) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3915) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3917) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3917) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3919) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3919) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3920) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3920) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3921) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3921) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3922) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3922) | Closed. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3923) | Timed out waiting for shutdown. Performing an immediate socket close. | 2018-09-26 12:58:50
HTTPS ameritrade02.streamer.com:443 (3923) | Closed. | 2018-09-26 12:58:50
TD Ameritrade | Streamer request #3806 initiated. | 2018-09-26 12:58:51
HTTPS ameritrade02.streamer.com:443 (3955) | Creating socket. Using TLS 1.0. | 2018-09-26 12:58:51
HTTPS ameritrade02.streamer.com:443 (3955) | Connecting to IP: 198.200.171.138. | 2018-09-26 12:58:51
HTTPS ameritrade02.streamer.com:443 (3955) | Encryption stream error encountered when processing received data. Failed to read incoming decrypted data from the incoming binary I/O stream. error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure; error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure | 2018-09-26 12:58:51
HTTPS ameritrade02.streamer.com:443 (3955) | Signaling to core to close socket | 2018-09-26 12
Date Time Of Last Edit: 2018-09-27 22:22:38
[2018-09-26 19:21:00]
John - SC Support - Posts: 37369
In order to fix the problem with the TD Ameritrade Data, perform the following steps:
Go to "File >> Data/Trade Service Settings".
Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com
Reconnect to the data feed by selecting, "File >> Disconnect" and then "File >> Connect To Data Feed".
