Date/Time: Wed, 22 Jan 2025 13:12:11 +0000
URGENT 2nd sc instance to ib
View Count: 832
[2018-09-26 18:45:46]
User472677 - Posts: 356
I have been running two instances of sc. one connected to tws and other to ameritrade. with ameritrade not working, I want to connect the second sc instance to ib. Insc I have changed the instance number for the second instance but it still does not connect. all other settings of the second instance are the same as the first instance. first instance connects to tws just fine. Please help
[2018-09-26 21:18:36]
Sierra Chart - Max - Posts: 5779
In order to fix the problem with the TD Ameritrade Data, perform the following steps:
Go to "File >> Data/Trade Service Settings".
Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com
Reconnect to the data feed by selecting, "File >> Disconnect" and then "File >> Connect To Data Feed".
Sierra Chart Support
[2018-09-27 13:05:03]
It does not help to post something as urgent. When you post something urgent, about a connectivity problem to an external service, it does not receive any priority from us.
