Date/Time: Wed, 22 Jan 2025 13:11:00 +0000
TDAmeritrade connection
View Count: 1306
[2018-09-26 16:23:38]
User653934 - Posts: 28
TDAmeritrade stocks connection has stopped streaming. They say there isn't a problem on their side. My futures stream fine with another broker.
[2018-09-26 19:18:45]
John - SC Support - Posts: 37369
In order to fix the problem with the TD Ameritrade Data, perform the following steps:
Go to "File >> Data/Trade Service Settings".
Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com
Reconnect to the data feed by selecting, "File >> Disconnect" and then "File >> Connect To Data Feed".
[2018-09-27 11:51:26]
I downloaded the updated version of SC and data is streaming now. Thank you.
[2018-09-27 15:00:24]
This was a TD Ameritrade problem and using an updated version of Sierra Chart would not help. You need to follow the instructions given above. And also TD Ameritrade has now resolved the issue.
Date Time Of Last Edit: 2018-09-27 15:00:45
