Date/Time: Wed, 22 Jan 2025 12:56:19 +0000
[Programming Help] - Alerts for Divergence indicator
View Count: 1219
[2018-09-26 03:58:21] |
user8222 - Posts: 21 |
Hi, I am trying to setup an alert system for when my Delta Divergence indicator plots a point on my chart. I would like it to alert me on all coins I have on multiple timeframes(1h, 4h, 6h). Is this possible? In my studies - Alerts panel I have it 'enabled', yet I have yet to hear any alerts go off even though they were on the charts. Do I have to have that actual chart open to get the alert? Thanks. |
[2018-09-26 05:12:17] |
Yes this is possible. The chart does need to be open but it does not need to be visible. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-27 03:11:58] |
Will it work if I put the charts with timeframes I want notifications on in a separate chartbook with them enabled, even if I don't have that chartbook tab opened? Thanks.
