Date/Time: Wed, 22 Jan 2025 11:51:26 +0000
Sierra Chart Market Data Subscription
View Count: 1604
[2018-10-01 13:14:38]
User94606 - Posts: 327
I read post #22 and tested it and it is working fine. However, when I do a "New Instance" of Sierra Chart and select either ES or CL, the "M" does not display on any charts. I then logged in to my live account and still does not show "M". Is this correct?
Also, I noticed that the market depth on CL is only 10 levels whereas the ES greater than 10 levels. Can you confirm if this is correct?
[2018-10-01 18:40:14]
When using a sub instance of Sierra Chart through File >> New Instance, you will not see the [M] but this data feed is still being used for the symbol if you do see the [M] indicator for the symbol in the main instance of Sierra Chart.
More levels of depth for CL will be coming at the end of this week.
