Date/Time: Wed, 22 Jan 2025 12:48:08 +0000
IQFeed
View Count: 650
[2018-09-25 21:05:00] |
Thembas - Posts: 2 |
Thank you for extending the trial. IQFeed trial includes SAFEX JSE Futures data but this is not showing in SC. The Symbol for All Share index in IQFeed is ALJ#. This is also one of the exchange I would to test using SC numbers bars. Thanks
[2018-09-25 23:39:36] |
We will set up this symbol. Just give us until tomorrow.
[2018-09-28 03:32:30] |
These symbols have now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
