Date/Time: Wed, 22 Jan 2025 09:58:00 +0000
Sub-Instances
View Count: 674
[2018-09-25 18:25:45] |
User63042 - Posts: 19 |
I keep SC fairly up to date, currently on 1809. I have noticed that after a recent update SC no longer stores my sub-instances instruction on General Settings, Instances to Run on Startup. I normally have this set at 2,3 but the instruction was cleared. After re-entering 2,3 it works on an SC restart but does not store the instruction, then after a computer restart it does not work, just runs one instance - need to enter 2,3 again. Best Colin |
[2018-09-25 18:31:39] |
This is resolved. Update to prerelease version 1811.
