Date/Time: Wed, 22 Jan 2025 13:34:45 +0000
pullback column`width
View Count: 752
[2018-09-25 16:36:13] |
User99934 - Posts: 227 |
Hi, Could you please tell me why when using number bars,bid x ask, ask bid difference profile outline, based on askvol bidvol percentage, in both column 1 and the pullback column 1, the pullback width is just a few pixels wide no matter if the pullback data is the same as the regular column data? Thank you Date Time Of Last Edit: 2018-09-25 17:35:13
[2018-09-27 18:50:27] |
Are you able to duplicate this?
[2018-10-01 05:22:07] |
Problem continues in version 1814.
[2018-10-03 19:43:40] |
Yes, we are able to reproduce this, and this will be resolved. We apologize for the delay.
[2018-10-04 15:19:40] |
John - SC Support - Posts: 37369 |
This has been resolved in the current release (v1815). To update, follow these instructions: Software Download: Fast Update
