Date/Time: Wed, 22 Jan 2025 09:53:45 +0000
Gold (CME) Market Depth
View Count: 1454
[2018-09-25 13:01:44] |
User78442 - Posts: 260 |
My gold chart now shows a chart DOM with 70+ levels. I tried to limit this to max depth 10 but it does not take the setting. Please advise.
[2018-09-25 17:11:44] |
Update to the current version of Sierra Chart following the instructions here: Software Download: Fast Update And then you can control the number of levels displayed with this Chart Setting: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-25 17:12:04
