Date/Time: Mon, 27 Jan 2025 19:09:27 +0000
Undocumented function
View Count: 886
[2018-09-24 16:56:02] |
maxpi - Posts: 181 |
Is "sc.AddAndManageSingleTextDrawingForStudy" documented? Search of the site does not reveal it.
[2019-02-20 16:12:07] |
jmt816 - Posts: 45 |
ran across your post while looking for exactly the same thing! I suspect you discovered it the same as I did, in the sample code. Hopefully you already found the answer, but if not, and for anyone else in the same boat, here's what I found: It is defined in "sierrachart.h". Just needed to change my "search in files" to look in the header files rather than the cpp. Of course, it sure would be nice to have it in the documentation as well! |
[2019-03-05 23:24:17] |
This function is now documented.
[2019-03-06 08:50:53] |
Thanks! Not sure why it did not come up in the site search. Finally dug and found it, but for anyone else checking, here's the link to it: sc.AddAndManageSingleTextDrawingForStudy() |
