Date/Time: Wed, 22 Jan 2025 09:53:45 +0000
alert bug
View Count: 585
[2018-09-24 15:36:04]
User472677 - Posts: 356
after the last upgrade, a new bug has popped up. In quote board, when an alert starts ringing, it can not be stopped by changing the alert price. the only way to stop the sound is to exit sc.
for example the alert is set at equal or greater than $23.88. The stock moves up to $24.89. The alert sounds and pop up
$24.10. stock is at $23.90. if pop up window is closed after the change it keeps on popping up and the sound does not stop.
[2018-09-24 18:13:33]
please reply
[2018-09-24 19:50:43]
We need time to test this.
For the particular alert number you are using with the Price Alert, how many times do you have it set to play?
Date Time Of Last Edit: 2018-09-24 19:51:54
