Date/Time: Sun, 24 Nov 2024 12:06:35 +0000
buy and sell columns missing in sreadsheet for trading
View Count: 1244
[2013-10-25 13:25:24] |
User021827 - Posts: 174 |
hi when I added spreadsheet for trading to chart, the buy and sell columns were blank and sheet 2 was blank on sheet 1 , it says to modify and enter formulas for this sheet on sheet 2 sorry i am confused. did i miss something simple ? shane |
[2013-10-27 07:36:13] |
Please refer to the various Spreadsheet Study inputs documented here: https://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudyInputs.html#SpreadsheetStudyInputs You need to see what Sheet the data is outputted to and what Sheet is used for the formulas. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-27 07:36:50
