Date/Time: Tue, 29 Sep 2026 04:29:27 +0000
Is there a tool to search by sounds ?
View Count: 913
[2018-09-24 07:47:44]
User360283 - Posts: 538
I have many studies and seem to have a sound alert that is occurring but I can't find the study.
Is there a way to search using the sound to find the study?
thanks
[2018-09-24 19:10:42]
Yes this is through the Alerts Log tab of the Alert Manager:
Alerts Manager
[2018-09-24 19:11:31]
The easiest way is to start with the Alert Manager and see what chart and study is causing the alert. The first part of the Alert Text gives you the Chart followed by the Study.
If there are multiple versions of the same study on the same chart and they have different sounds, then you could look at which study is using which alert with that particular sound. The Alert Manager gives you the number of the sound being used in parentheses at the end of the Alert Text. The documentation for setting sounds for different alerts can be found here:https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings
Also, the text of the alert is shown in the Alert Manager, which should help you find the particular study that is using it.
