Date/Time: Wed, 22 Jan 2025 09:51:07 +0000
[Programming Help] - Please add a Subgraph of Strings
View Count: 721
[2018-09-23 03:01:54] |
User553714 - Posts: 184 |
Hi, I have read carefully your documentation and as far as I can tell, you can't use a subgraph to display unique/different string messages at different Index positions? I played around with DRAWSTYLE_TEXT & Subgraph.TextDrawStyleText but this only allows setting one style text per subgraph. Can you please consider adding a Subgraph of strings? This would be a massive improvement as you can then use this subgraph as a messaging service on the chart itself to display different string/text identifiers at any Index required. Regards |
[2018-09-23 20:55:59] |
Yes this is correct. What you are requesting would not be added. You need to use the Text drawing tool instead: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
