Date/Time: Thu, 25 Apr 2024 10:17:25 +0000
Suggestions/Requests
View Count: 719
[2018-09-22 16:05:32] |
User710890 - Posts: 23 |
Hello, Thanks for making an excellent piece of software. Here are some small requests. 1. Fix Bid & Ask Depth Bars Subgraph settings not saving for Bid Depth Vs Ask Depth calculation mode. Every time I reload Sierra Chart, the settings are lost. 2. Add option to VbP study to have a hologram outline (see attached screenshot). I've emulated this using 2 Vbp Studies layered on top of one another. 3. Add a study that grabs the OHLC values for a bar, so you can plug any other study in as inputs. (Unlike Study Overlay - OHLC, this would grab the value on first tick, value on closing, and the min-max during bar formation) 4. NOVALUE or NULL for Spreadsheet Formula Study. Currently it is not possible (to my knowledge) to use an IF statement, and either set something to a value, or null. Setting something to zero instead messes up the subgraph by showing zero values when you only want to show markers when something is true. Thank you |
VbP_Outline.png / V - Attached On 2018-09-22 15:54:42 UTC - Size: 12.45 KB - 242 views |
[2019-08-25 04:02:04] |
1. Make sure with that study the Automatically Set Draw Styles Input is set to no: Bid & Ask Depth Bars 3. This is not going to be reasonably possible. You need to use the Study Overlay-OHLC study. Also refer to this study: Study Subgraph Daily High Low 4. The Spreadsheet Formula study supports a Draw Zero Values Input. You will want to use that. Also look at this Draw Style: Chart Studies: Line - Skip Zeros (ACSIL: DRAWSTYLE_LINE_SKIP_ZEROS) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
