Date/Time: Wed, 22 Jan 2025 09:45:09 +0000
Instances to run on startup box settings are not being saved
View Count: 660
[2018-09-22 12:22:31] |
User995923 - Posts: 64 |
Hello I want to add additional sierra chart instances and when I go to Global Settings -> General Settings-> I type the number 2 on the box Instances to Run on Startup and click Apply and then Ok. When I open the general settings again, the instances to run on startup box is empty. Maybe is there any problem with the latest update? Thanks |
[2018-09-23 21:30:21] |
Yes we do see this. Not sure what has gone wrong with that. But we will get it corrected. It may be a couple of days though before we get a new release out.
