Date/Time: Wed, 22 Jan 2025 09:57:05 +0000
Trade Window - Cancell All button stays depressed
View Count: 610
[2018-09-21 20:10:43]
Meklon - Posts: 220
Hello support,
I have encountered something odd. On the trade window, after pressing "Cancel ALL" button, it stays depressed (similar if you would click (press the button)) and not release it. Is this normal behavior? It doesn't happen when pressing any other buttons (Reverse, Flatten). Seem to be happening on all charts. Please see attached image.
Date Time Of Last Edit: 2018-09-21 20:11:29
imageCancel_All.png / V - Attached On 2018-09-21 20:10:28 UTC - Size: 14.81 KB - 222 views
[2018-09-21 21:39:41]
John - SC Support - Posts: 37369
Yes, this is normal behavior. It stays in the Unavailable state if there are no orders to cancel. Once there are orders available, it will change its state.
[2018-09-21 21:47:51]
Meklon - Posts: 220
Great, thank you for confirming it! Just wanted to make sure not running a faulty version that may affect the order routing.
