Date/Time: Wed, 22 Jan 2025 09:43:14 +0000
Cross Hair
View Count: 510
[2018-09-21 19:47:21] |
Monserrate G - Posts: 27 |
I have 3 monitors with charts opened on all 3. When I go to other monitors the cross hair is sometimes not visible. In trying to find the cross hair I sometimes trigger a trade by mistake. Do you have a suggestion on how I can travel between monitors and not lose sight of the cross hair. Thanks |
[2018-09-21 21:02:02] |
If you are referring to what is called the pointer you should go into the operating system control panel and change the appearance of it to a different one.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-21 21:02:22
