Date/Time: Wed, 22 Jan 2025 10:07:02 +0000
Can ASCIL be used to display a warning/message box
View Count: 1136
[2018-09-21 17:25:54]
User701453 - Posts: 176
Can ASCIL be used to display a warning/message box if a user selects an input value that would a violate a required rule?
Like selected an input Yes/No option to use a stop loss, but dont enter the stop lost amount in another input field.
Would like to be able to alert the user when the study recalculates a warning of a potential high risk result.
[2018-09-21 19:45:36]
You could to add a message to the Message Log and have it open:
sc.AddMessageToLog()
[2018-09-21 19:57:20]
Thanks that will get me started.
Also, is it possible to remove the "C" from the open P&L format.
Using the example code files, I`m able to display the open P&L on the chart.
However the "C" on the end of it and I would like to remove that character.
I didnt see anything in the documentation on how to do that.
Perhaps I overlooked it.
[2018-09-21 20:25:32]
Never mind on the text format.
I figured it out..
It might not be pretty, but it works..
SCString Text;
SCString PLString;
  PositionProfitLossDisplayEnum ProfitLossDisplayFormat = (PositionProfitLossDisplayEnum)(0);
  sc.CreateProfitLossDisplayString(PositionData.OpenProfitLoss, PositionData.PositionQuantity, PPLD_CURRENCY_VALUE, PLString);
  Text.Format("Open P&L: $%s", PLString.GetChars());
  Text = Text.Left(Text.GetLength() - 1);
Date Time Of Last Edit: 2018-09-23 00:17:38
