Date/Time: Tue, 13 Oct 2026 07:55:55 +0000
Bitmex Not working
View Count: 1627
[2018-09-21 16:37:09]
atlasq - Posts: 2
Hi
I don´t know whats going on but I can´t get my sierra chart to work.
Could you please verify?
tMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-09-21 10:52:26
BitMEX WebSocket | Connecting to WebSocket server. | 2018-09-21 10:52:26
BitMEX WebSocket socket (2253) | Creating socket. Using TLS 1.2. | 2018-09-21 10:52:26
BitMEX WebSocket socket (2253) | Connecting to IP: 54.171.58.46. | 2018-09-21 10:52:26
BitMEX WebSocket | Opening WebSocket. | 2018-09-21 10:52:26
BitMEX WebSocket | Sending WebSocket handshake. | 2018-09-21 10:52:26
BitMEX WebSocket | Header line. HTTP/1.1 403 Forbidden | 2018-09-21 10:52:27
BitMEX WebSocket | WebSocket not connected. Handshake acknowledgment: HTTP/1.1 403 Forbidden | 2018-09-21 10:52:27
BitMEX Trading Direct | WebSocket closed. | 2018-09-21 10:52:27
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-09-21 10:52:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-21 10:52:27
BitMEX WebSocket socket (2253) | Initiating close of socket by core. | 2018-09-21 10:52:27
BitMEX WebSocket | WebSocket closed. | 2018-09-21 10:52:27
BitMEX WebSocket socket (2253) | Shutdown started. Waiting for graceful close. | 2018-09-21 10:52:27
BitMEX Trading Direct | Disconnected. | 2018-09-21 10:52:27
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-09-21 10:52:27
[2018-09-21 16:58:30]
atlasq - Posts: 2
SO how can I fix it?
[2018-09-21 18:46:22]
These are the relevant messages. Select File >> Disconnect. Wait a certain amount of time. How long we do not know. And then connect to the data feed again with File >> Connect to Data Feed. We would think you might have to wait at least an hour. None of this is within our control.
