Date/Time: Wed, 22 Jan 2025 10:08:32 +0000
Using API /w ACSIL
View Count: 1653
[2018-09-21 01:37:33]
User439067 - Posts: 48
Is there any way to call an external API from a c++ ACSIL study? I trade futures and setup some entry buttons to click to create my orders. I'm currently using a forex broker that does not support Sierra but has an API. I would love to be able to use the charting platform to call the API to simply create my orders with a click of a button like I am used to.
Thanks,
[2018-09-21 19:16:59]
Yes you can. You create an ACSIL study using C++ so you can do whatever you require and you have full access to the Windows API as well.
Date Time Of Last Edit: 2018-09-21 19:17:25
[2018-09-22 21:09:15]
Is there any way to manage a position via sierra charts chart trading? like I call the API to open a position and then make the position / order lines and be able to change them on the chart to produce other API calls etc?
Would love a link to the docs on how to accomplish that. Working on a big project I'm excited about. Thanks! You guys are the best.
[2018-09-23 23:40:08]
You really need to create a DTC trading server and use the DTC client within Sierra Chart to accomplish this:
Data and Trading Communications (DTC) Protocol Test Client
