Date/Time: Sat, 01 Feb 2025 06:57:36 +0000
Volume At Price Threshold Alert V2
View Count: 931
[2018-09-21 00:32:23] |
dbouzas - Posts: 2 |
Good Evening, I am looking to see if I can get some changes to this study for the following. 1) When using it to identify a significant diagonal ratio, you cannot set a minimum volume threshold. So for example, if set at 700%, there is no way to filter something with 1 market order on the bid and 7 on the ask, even though these events may not have enough volume to be significant. 2) The clearing of the lines. The lines will clear with this method the moment they are touched. But I would like to see if they will only clear on a bar close under/over the line, so it gives the level a bit more leeway. Are these things possible to do now or is that something we could see in the future? TY, DBS |
[2018-09-21 19:18:56] |
1) We will look into adding this. Give us at least a few weeks to get to this though. 2) The decision on where to stop the Extension Lines is a general routine that is used throughout Sierra Chart. It is not something that we would want to change just for this study and changing it for all places that have Extension Lines is a large undertaking. Therefore, this is not something that we will be doing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-23 01:36:09] |
ok, ty
[2019-07-02 00:11:39] |
apollofl - Posts: 95 |
Support, Have Item #1 been completed yet. It would be nice to filter for low volume comparison. Thanks 1) We will look into adding this. Give us at least a few weeks to get to this though. 2) The decision on where to stop the Extension Lines is a general routine that is used throughout Sierra Chart. It is not something that we would want to change just for this study and changing it for all places that have Extension Lines is a large undertaking. Therefore, this is not something that we will be doing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. If possible please keep your questions brief and to the point. Please be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation If your question/request has been answered and you do not have anything further, then it is easiest for us if you do not reply again to say thank you. Have Item #1 been completed yet |
[2019-07-02 14:56:55] |
John - SC Support - Posts: 37656 |
No, this has not been done yet. We just got busy with other things and have not had a chance to get back to this. We still want to get it completed, but we cannot say when we will be able to.
