Date/Time: Wed, 22 Jan 2025 09:53:27 +0000
Global profit loss test
View Count: 474
[2018-09-20 19:36:44] |
User993067 - Posts: 156 |
Trying to test Global Profit loss feature...had enough days of being +800 and ending up minus -800....does this work on replay. Does not seem to be. Initial trigger is +600 Go Flat Trigger is 400 Trail both values is +200... So if I get to +800 new flat trigger is 600 correct? after testing functionality in replay....+1000 in sim1 account...let it draw for test...and no controls engaged. |
[2018-09-20 20:05:53] |
No, replay is no longer supported with that feature. There was too much associated complexity with that.
