Date/Time: Sun, 24 Nov 2024 12:04:33 +0000
NYSE Tick --setting it up
View Count: 1365
[2013-10-25 01:20:24]
37010476 - Posts: 22
When I create the Tick chart to go underneath my price chart, and wish to see the extreme readings, + or -975-1000, I am noticing that there are absolutely no readings that are that extreme and so I know something is wrong. I set it up as a 1 minute as I am trading off a 1 minute chart.
Do you know what I might be doing wrong?
[2013-10-25 14:46:53]
M5amhan - Posts: 468
nothing is wrong, this is the market conditions we are trading in.. if you are seeing +1000/-1000 readings regularly on other $TICKs (from other packages) then those are calculated very sensitively
[2013-10-25 17:01:51]
It is not likely there is a problem with the data. However, please post an image of what you are seeing for $TICK, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
