Date/Time: Wed, 22 Jan 2025 09:59:23 +0000
HKEX professional data feed
View Count: 653
[2018-09-20 15:48:51] |
User644165 - Posts: 25 |
Hi All, I see that Sierracharts provides data for HKEX exchange, but I cannot see the professional data feed for HKEX. Can you please let me know the cost of the SC HKEX pro data feed? Thanks in advace. |
[2018-09-20 19:25:20] |
If you do not see it listed it means that the exchange gratefully does not look at a professional any differently.
