Date/Time: Wed, 22 Jan 2025 09:59:54 +0000
I am Past Customer With A Custom Data Question
View Count: 649
[2018-09-19 17:53:34]
User580618 - Posts: 7
Hi...
Question ...
I have an Excel spreadsheet that gets quotes from a Reuters RTD feed... I take some of those quote values and derive about 8 individual sum data points that update 8 sql data tables every 1 second... Is there a way to take this data and chart it in Sierra Charts...
Can i do this and would their be an extra charge payment for doing the above... Of course i would activate SC and pay for SC usage and ALSO have either a Sierra Charts data subscription or a IB data feed setup... but also would like to do the above custom data charting too.
Can you advise me on this ?
I can code but avoid it if there is a way to do the same with a template setup... etc.
thanks..
[2018-09-19 20:21:30]
If you do not need to chart this data in real-time, then refer to the following information regarding importing data.
Exporting and Importing Intraday Data Files
You do not need anything special in terms of data subscriptions.
[2018-09-19 20:41:41]
Yes... It needs to be in REAL TIME...
[2018-09-19 21:26:25]
Really you would have to program a custom solution for this and use ACSIL to access the data:
Advanced Custom Study Interface and Language (ACSIL)
Date Time Of Last Edit: 2018-09-19 21:26:40
