Date/Time: Wed, 22 Jan 2025 10:01:49 +0000
Horizonal Grid Lines Distort and Move
View Count: 706
[2018-09-19 15:54:27] |
marwhitt - Posts: 29 |
Horizontal grid lines, which are aligned with prices on vertical price column on right side of chart, do not maintain set spacing. Instead, they change the spacing, and distort. Instead of one line per price, I have one line for every other price; OR my scale also changes by itself, from 1-point (my setting) to 2 points, or a mix (see image). I would like the prices to stay at 1-point, and the lines to stay at 1 line per price point, but still be able to move the price action up or down within the chart frame.
Date Time Of Last Edit: 2018-09-19 15:55:18
[2018-09-19 15:55:53] |
When you see a problem post an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image That other screenshot is not acceptable. It is basically a camera image. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-19 15:56:09
[2018-09-20 16:56:56] |
My apologies. Proper image can be found here: http://www.sierrachart.com/image.php?Image=1537462094769.png This is a mild example; most of the time, several lines are missing when it does this. I have to drag the vertical price column to straighten it out. |
[2018-09-20 20:04:49] |
Set the Scale Increment to 0 for that chart: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-20 20:14:11] |
I have scale increment set to 1.00 to avoid a 2-point scale, which is what happens when set to 0. Please advise on how to keep the horizontal grid lines consistent with the prices. Thank you. |
[2018-09-21 07:41:46] |
Can you provide us that particular chart and we will test it. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-21 19:53:52] |
chart attached
2018 Basic.Cht - Attached On 2018-09-21 19:53:07 UTC - Size: 65.15 KB - 324 views |
