Date/Time: Wed, 22 Jan 2025 09:47:13 +0000
Is there a way to access Zig Zag text values with Color Bar for Alert Condition?
View Count: 788
[2018-09-18 23:35:57]
jackbravo - Posts: 69
I'm wondering if there is a way to access the information from the Zig zag indicator Text values programmatically using the Color Bar for Alert condition. I'm trying to ALERT whether the last high zig zag point is higher than the previous high zig zag point. Also, the same for the low zig zag points.
I have tried using the Highest N-bars indicator overlayed on Zig Zag, but it gives me a 0 line when using it on the Zig Zag Text subgraph. I also don't see a way to separate the high values from the low values.
Thanks for any help.
[2018-09-20 13:29:53]
ForgivingComputers.com - Posts: 989
SG2 is what generates the text labels, but it is a number internally.
0: In between H and L
1: LH
2: HH
3: HL
4: LL
[2018-09-20 16:28:44]
Sawtooth - Posts: 4158
You would need to use the Spreadsheet System/Alert study so that you can create persistent variables of the previous ZZ leg high and the previous ZZ leg low.
[2018-09-20 18:39:24]
Here is the documentation to reference that particular label Subgraph:
Zig Zag: Text Labels Subgraph Description
