Date/Time: Sat, 26 Apr 2025 09:40:33 +0000
Number Bars total is wrong.
View Count: 683
[2018-09-18 20:38:45]
User800328 - Posts: 50
Hi there,
I am using the Number Bars study on my chart and it seems that the (Ask Vol- Bid Vol) is coming wrong on few columns and then its correct on few columns.
The 6the column in the calculated Values study shows -1877 when clearly if you count, the value is off.
http://www.sierrachart.com/image.php?Image=1537302774421.png
I have attached the chart settings file for this chart. I also made sure that I have Tick Data. I am also using a paid data feed.
Thanks.
imageScreen Shot 2018-09-18 at 1.35.32 PM.png / V - Attached On 2018-09-18 20:36:12 UTC - Size: 118.23 KB - 206 views
[2018-09-18 21:11:02]
We need you to explain how you come to the conclusions that you do.
[2018-09-18 21:17:14]
Ok fine. Here is the 6th column total. I add the right side (Ask Vol) and substract from the total of the Bid Vol (Left Side).
Ask Vol - Bid Vol = (91+848+243+734+146+399) - (37+12+766+463+784+846+748) = -1195.
But the calculated values show -1877.
How come ?
[2018-09-18 21:25:41]
The column width is too narrow. You are not seeing the full numbers.
[2018-09-18 21:37:34]
You are absolutely right. When I zoomed in, I see the complete numbers.
Sorry my bad. Appreciate your prompt reply.
One last question: Can you please tell me why are some numbers text in WHITE color and rest in RED/Green. I expect Red when BID is greater than Ask and Green when Vice Versa.
For example, in the same 6the column, the third row 766|243, both are WHITE. I don't know why and what it means ? Can you please tell me . ? Do you need the studies section to determine ?
[2018-09-19 03:53:13]
I think I got it. Thank-you.
[2018-09-19 05:04:15]
Okay thank you. The coloring methods are thoroughly documented on the Numbers Bars page:
Numbers Bars
