Date/Time: Wed, 22 Jan 2025 09:50:02 +0000
some Charts often missing
View Count: 439
[2018-09-18 14:32:26] |
Willson - Posts: 176 |
Using ver 1806, but same problem with older versions starting a few months ago. Some charts open fine, others dont open. I dont see error in log file, but I might not know the clue. The charts that do open seem to work. The missing charts are also missing in the CW list and the "Windows/Windows and chartbook" menu list. Any suggestions to repair this?
[2018-09-18 18:31:05] |
This must be an operating system level issue. The Windows operating system is failing to create the chart windows. We recommend using multiple instances as explained here: http://www.sierrachart.com/index.php?page=doc/NewInstance.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
