Date/Time: Wed, 22 Jan 2025 10:05:40 +0000
Enlarge Chart Candles with
View Count: 590
[2018-09-18 14:13:35] |
User369868 - Posts: 6 |
I am used to both enlarging and reducing candle size with the + and - keys. Suddenly I can do neither. Is there a setting that I've accidentally changed which stops me from using this shortcut? Thank you for your help |
[2018-09-18 21:20:00] |
Refer to: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) In general if you have trouble with keyboard shortcuts we cannot help. Because this requires the operating system to work correctly. But you can always access those commands from the Chart menu or add them to the Control Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-18 21:20:40
