Date/Time: Wed, 22 Jan 2025 10:07:12 +0000
Pivot Points change after update
View Count: 714
[2018-09-18 09:06:22]
StevenCaleb - Posts: 14
I downloaded the update this morning and now the pivot points change when I change time frames. This has not been a problem in the past.
[2018-09-18 10:45:11]
Trader&Hunter - Posts: 131
same here. I use a custom one and this should NEVER update with when changing time frames.
[2018-09-18 17:37:59]
What is the exact name of the study you are using? If you are using a custom study we cannot help with that and will not help. Also, really this does not make any sense because nothing has changed with the Sierra Chart provided Pivot Points studies. Furthermore, we do not observe what you are saying either.
Date Time Of Last Edit: 2018-09-18 17:38:19
