Date/Time: Mon, 02 Nov 2026 00:15:41 +0000
background color on chart
View Count: 5836
| [2018-09-17 23:53:04] |
| User828417 - Posts: 32 |
Is it possible to change the background color on individual charts as opposed to a global setting?
| [2018-09-18 01:46:19] |
Yes of course. Refer to: Graphics Settings: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-09-18 16:52:11] |
Got it, thank you. Is there a way to create a toolbar button (shortcut) for the chart background setting? |
| [2021-03-17 13:27:57] |
| Vito Anasto - Posts: 4 |
Hi, Do you have a sales line I can speak with? I read through the boards but I'm not sure exactly which package and data service to choose. Thanks |
| [2021-03-17 15:34:08] |
| John - SC Support - Posts: 48377 |
User828417: There is not a way to setup a Control Bar Button for a particular color option. But, be aware of the option to save and restore multiple Global Graphics Settings. Refer to the following: Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-03-17 15:36:06] |
Vito Anasto: We do not have a Sales line. You will find the differences in the packages here: Description of Service Packages and Pricing: Packages For data services, refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart If you have specific questions, feel free to post them and we will answer them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
