Date/Time: Wed, 22 Jan 2025 09:56:51 +0000
Compile Error in V1806
View Count: 636
[2018-09-17 21:29:32]
ertrader - Posts: 681
Hi support.. I am getting a compile error (64 bit). Below are the results. Compiled fine in 1803.
-- Starting remote build of Custom Studies Source files: AutoTradeSignalV9bHLMR.cpp. 64-bit -- 17:27:16
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
In file included from scstructures.h:84:0,
from sierrachart.h:15,
from AutoTradeSignalV9bHLMR.cpp:1:
SCString.h: In constructor 'SCString::SCString(const char*, int)':
SCString.h:201:41: error: 'min' was not declared in this scope
StringLength = min(Length, MAX_LENGTH);
SCString.h:201:41: note: suggested alternative:
In file included from /usr/lib/gcc/x86_64-w64-mingw32/5.3-win32/include/c++/algorithm:62:0,
from scstructures.h:49,
/usr/lib/gcc/x86_64-w64-mingw32/5.3-win32/include/c++/bits/stl_algo.h:3451:5: note: 'std::min'
min(initializer_list<_Tp> __l, _Compare __comp)
AutoTradeSignalV9bHLMR.cpp: In function 'void scsf_AutoTradeSignalV9bHLMR(SCStudyInterfaceRef)':
AutoTradeSignalV9bHLMR.cpp:1419:71: error: 'max' was not declared in this scope
r_FirstIndexIncluded = max(0, Index - TimePeriodLength.GetInt()+1);
AutoTradeSignalV9bHLMR.cpp:1419:71: note: suggested alternative:
/usr/lib/gcc/x86_64-w64-mingw32/5.3-win32/include/c++/bits/stl_algo.h:3463:5: note: 'std::max'
max(initializer_list<_Tp> __l, _Compare __comp)
-- End of Build -- 17:27:19
Date Time Of Last Edit: 2018-09-17 21:30:28
[2018-09-18 03:28:18]
This is resolved in version 1807.
[2018-09-18 05:20:14]
In V 1807 I am getting the following error message still:
-- Starting remote build of Custom Studies Source files: AutoTradeSignalV9bHLMR.cpp. 64-bit -- 01:18:11
-- End of Build -- 01:18:15
[2018-09-18 15:06:02]
John - SC Support - Posts: 37369
Use std::max() instead of just max().
[2018-09-18 18:12:12]
We will resolve the issue.
Date Time Of Last Edit: 2018-09-18 18:12:52
[2018-09-18 20:46:00]
This change gave the following error
Will appreciate it
In file included from sierrachart.h:15:0,
scstructures.h:70:29: error: expected unqualified-id before '(' token
#define max(a,b) (((a) > (b)) ? (a) : (b))
AutoTradeSignalV9bHLMR.cpp:1419:34: note: in expansion of macro 'max'
r_FirstIndexIncluded = std::max(0, Index - TimePeriodLength.GetInt()+1);
-- End of Build -- 16:41:37
Date Time Of Last Edit: 2018-09-18 20:57:20
[2018-09-18 21:47:03]
We are working on a solution.
[2018-09-19 03:17:15]
V1808 compiling OK
