Date/Time: Wed, 22 Jan 2025 09:56:34 +0000
How to Retain Stationary Text Drawings After Symbol Rollover?
View Count: 983
[2018-09-17 20:31:17] |
gayer2428 - Posts: 89 |
I have a few Stationary Text drawings on my charts. After a symbol rollover they are lost and I have to manually recreate them. I have tried using Manage Chart Drawings (under Tools menu) to lock drawings but it doesn't prevent them from getting erased. So my question is, is there any way of retaining Stationary Text drawings after symbol rollover or manually changing symbol? Thank you. |
[2018-09-18 21:13:32] |
Refer to: https://www.sierrachart.com/index.php?page=doc/ChangingFuturesContract.html#ChartDrawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
